Bought a 2003 Tacoma TRD
Hi there
After many searches i finally closed on a 2003 Toyota Tacoma TRD manual V6 here in Lebanon.
I had looked at importing one from the US with lower miles but did not work out.
The truck has 254 k miles but mechanically is is good shape. Had it inspected by a Toyota mechanic on a scanner all looks good.
Issue is with the frame. It does has superficial rust and has been painted.
I guess i would need to have the frame treated at a shop. Will cost around $400
Can someone shed light if Tacoma frame can take superficial rust and can this frame handle towing and off roading ( snatch towing) ??
I think your frame will be fine. You are not in a rust belt like the Northern US where Toyota had to recall many trucks. It can handle towing, however due to the torque/HP you won't have much luck towing anything over 3,500Lbs.
This Tacoma was imported from USA from MD ( Maryland).
On the recall did Toyota replace full frames ?
Jay
