Body Mounts
sark
42601-60262-03
New England
Looking for some clarity on choosing body mounts:
I understand what the diagram below explains as far as Types, but which mounts do we choose between 3&5, 4&7, and 6&8? My 1992 HZJ73 meets both conditions of the main diagram and the sub-diagram with the arrow.
Any ideas?
I removed the previous post because I believe I found the issue. Pretty sure I've been baited by the diagrams. The physical location of the numbers doesn't seem entirely accurate.
The list I'm going to order is below. I will post measurements and everything when the time comes on my build thread.
LocationPart NamePart NumberQuantity
Window Weatherstrip, RH67045-90K011
Window Weatherstrip, LH67046-90K011
1Bolt90105-101032
1Washer Plate90201-102034
1Cushion Upper52201-250202
1Cushion Lower52202-250202
1Tube90440-170212
1Nut90179-100152
1Nut, Lock94184-010012
2Bolt90105-100392
2Washer 90201-100942
2Washer Plate90201-102034
2Cushion Upper52203-600302
2Cushion Lower52204-600302
2Tube90560-122332
2Nut90179-100152
2Nut, Lock94184-010012
3Bolt90105-100392
3Washer 90201-100942
3Washer Plate90201-102034
3Cushion Upper52207-600402
3Cushion Lower52208-600102
3Tube90560-122332
3Nut90179-100152
3Nut, Lock94184-010012
5Bolt90105-100392
5Washer 90201-100942
5Washer Plate90201-102034
5Cushion Upper52203-600302
5Cushion Lower52204-600302
5Tube90560-122332
5Nut90179-100152
5Nut, Lock94184-010012
7Cushion52209-600202
7Bolt93381-180202
8Bolt90105-100392
8Washer Plate90201-102034
8Cushion Upper52201-600402
8Cushion Lower52202-600202
8Tube90440-170212
8Nut90179-100152
8Nut, Lock94184-010012
SummarizedBolt90105-101032
Bolt90105-100398
Bolt93381-180202
Nut90179-1001510
Nut, Lock94184-0100110
Tube90440-170214
Tube90560-122336
Washer 90201-100946
Washer Plate90201-1020320
Pos. 1Cushion Upper52201-250202
Pos. 1Cushion Lower52202-250202
Pos. 2&5Cushion Upper52203-600304
Pos. 2&5Cushion Lower52204-600304
Pos. 3Cushion Upper52207-600402
Pos. 3Cushion Lower52208-600102
Pos. 7Cushion Upper52209-600202
Pos. 8Cushion Upper52201-600402
Pos. 8Cushion Lower52202-600202
Total90 parts
Parts arrived, measurements here:
1Bolt90105-101032
1Tube90440-170212
1Nut90179-100152
2Bolt90105-100392
2Washer90201-100942
2Tube90560-122332
2Nut90179-100152
3Bolt90105-100392
3Washer90201-100942
3Tube90560-122332
3Nut90179-100152
5Bolt90105-100392
5Washer90201-100942
5Tube90560-122332
5Nut90179-100152
7Bolt93381-180202
8Bolt90105-100392
8Tube90440-170212
8Nut90179-100152
Bolt90105-100398
Bolt93381-180202
Nut90179-1001510
Tube90440-170214
Tube90560-122336
Washer90201-100946
Total90 parts
how were you baited. I think I am suffering from this
