Does anyone know if all of the rubber body mounting points are supposed to be bolted in place? My 1980 HJ45 Troopy has a couple of rubber body mounts in front of the rear axle where the rubber "puck" appears to just be sandwiched between the body and frame. There is no bolt through it. (I'm not referring to the two smaller rubber sections that sit on the axle hump on each side of the the frame.)
Should all body mounts be bolted in place or is my situation normal? I can snap photos if my description isn't clear.
