Hi,
Help please!
Could a blown inlet manifold gasket give low compression readings across all six cylinders?
I know the inlet manifold is leaking oil which I believe was from when the fuel was up to high and I was getting excessive blow by.
I installed a catch can just before I had it tuned for the second time by another specialist.
Compression test numbers are:
1/300psi 2/280psi 3/280psi 4/240psi 5/280psi 6/220psi
I have asked a similar question in another post but this question is specific to the inlet manifold.
Cheers
Help please!
Cheers
