Bleed AHC accumulator, but no fluid (1 Viewer)
SOCAL
I was trying to flush my ahc fluid tonight. However, when i bleed the accumulator, there were a little bit fluid came out. Then i try to bleed more, but no fluid came out. All others are fine. What could go Wrong?
Sounds like you are trying to bleed while in Low. No pressure in the system then. Bleed in Normal height, and let it drop as you bleed.
Sorry. Didn't read properly -- the Accumulator, not the globes...
The cylindrical accumulator gets pressure only at certain conditions. Can't remember exactly, but I think it was that if you go from Lo to N to Hi, and then back to N, you will always have pressure. Anyhow, easy to see if you use TechStream.
And, when you bleed it, you get only a certain amount, with good pressure, and then it stops abruptly by itself.
