Black Friday Blem sale coupon codes
Delta VS
Supporting Vendor
Boise, ID
Website
deltavs.com
Howdy all, hope you've had a good Thanksgiving this year.
Same as last year, putting up coupon codes for our stash of blem items. 98% cosmetic issues that most won't even notice, and a couple used items. These should be active at midnight tonight (no clue if they will activate midnight MST or PST or what), through Sunday night at midnight. The codes will work for as many blems as we have on the shelf. If you enter the code and it says "invalid" or something like that, it means they are all used up. One issue yet to be squared away is for the shifter consoles, can't get those codes to work as you would expect due to the part numbers and how the site works. If one of those is what you're after, check out with the code and I'll process a refund after the sale (-100$), this way the proper number of them can be dealt with. If you enter the code and it's green and says "-0$", something like the shifter console issue is taking place and if you check out I will refund the coupon amount after the sale.
Tried to make the codes descriptive enough you can tell if it's something you are looking for just by looking at the list so you don't have to go through and enter every code to see what it is or something.
Any low effort comments like "r ther n e "x" on teh list" will be ignored. You're here so that means you can read. Will try to answer questions in between family time.
Process for the codes is to add a normal product to the cart and enter code. That will apply the discount and signal on our end to send the blem.
Good luck, and may the odds ever be in your favor.
To be sure i understand, we will find the item on the blem.list on the site when it goes live, then use the coupon code? Or enter in a purchase for a new item with the coupon code and you will sort the correct product?
For the used radius arms, assuming bushings are already installed? Or should bushing installation be added to order?
They have bushings, the intention was bushings would be added to order. This might be one of the situations like the shifter console, new territory here…
Just add a new product to cart and check out with code. I need to edit op to make this clear.
And more than 1 code is possible for purchasing more than 1 item? Or separate transaction?
Website does not have ability to stack coupons unfortunately. If you order multiple things will refund extra shipping paid.
I got the 5L arms last year, might pick up a QPM or tailgate depending on the discount! What is the plb3?
I'm also not having any luck with the arm code
Interested in the 3" radius arms, but code didn't seem to work or was already used.
Delta-- please let me know if they're still available when you see this, thanks.
Thank you for the deal. I ordered the shift console that I've drooled over for so long!
