Pocket lockers work (2MK) by the
cross pin pressing the locking mechanisms apart under
load and engaging the teeth and thus you have a spool, in a turn you are (supposed) to let off
(unload) the accelerator pedal and the backlash will allow release and let the teeth skip over each other (ratchet sound
) per the over run side more than likely thus an interrupted spool.
In extreme situations you can really cause some damage, the kind its hard to drive home on....
cross pin,
carrier (super common, across the board not necessarily LC), locker bits & pieces....
Me I despise lunch box lockers for the damage they can do, and most people with a bad experience with them will tell you the same. Anyone who says "heck yeah! cheap! cheaper!!, I'd..."" has not had it happen to them
yet. They have horrible on road manners unless you are constantly accelerating while you drive (think sway in bad cross wind, and you got super SWB....hmmm?) you create
unload (every time you let off) and
load (every time you let on) situations, but if you are the "I know what I'm in for" kinda guy and go into this knowing then go for it.
Other wise selectable locker or a
GEARED limited slip would also be a good choice .
Bottom line I would ask myself what I wanted as far as off-road, and how much time I spent off-road. Sorta like "should I use a bias ply or radial?" ask yourself some questions and it'll come to you.
