Over the weekend I replaced the bushes within the sway bar as there was slight knocking within steering, as when inspected I could move the sway bar 2-3 mm within the sway bar bracket.(D Bush)
Therefore replaced the bushes, and found that bushes that came out were the exactly same type that I put in, and still there was 2-3mm play within the bracket, so I decided to add some rubber to within bracket to reduce the play with bush and bracket.
So the knocking has been removed but I must say the steering has slightly become a little heavy as a result.
Question?. is the play within sway bar bush and bracket normal or should it fit snug,
