- Joined
- Jan 2, 2014
- Threads
- 1
- Messages
- 2
I am posting about a BJ70 I recently got from a wreckers, so it has not run for a few years. It sounds like Rosco knows a fair bit about the EDIC, and I'm wondering if that is where my problem lies. The engine starts fine, but then idles at high revs (I'm not sure how high exactly, as the gauge is not working, the speedo and other gauges are working). I tried adjusting the screw to push the rod more towards the stop position, to hopefully lower the revs, but this just makes the revs drop until it stalls.
When put into gear and the clutch released, the revs drop a bit to a more normal idle level, but then applying the accelerator (which works via a venturi, which I don't know much about) does not increase the revs much. Holding the accelerator pedal flat to the floor, slowly the revs build up over time.
Also, when I turned the key to the off position, the engine did not cut out straight away, but the revs dropped and the engine stopped over 10 seconds or more.
Any ideas would be helpful.
Thanks.
Thanks.
