Birfields coarse or fine
Las Vegas,Nevada
I have a 1974 FJ assuming it is all stock, DO i have fine spline birfs or coarse,how many splines? My inner axles how many splines?outers?:confused:
Coarse spline outer axle stub- 6 spline
Fine spline inner axle shaft- 30 spline
Geez that was fast thanks POSER:)
I was thinking of putting a aussie up front,in this case maybe not.
Aussie up front with coarse splines=Busted birf. Ask me how I know. Get some Longfields and the Aussie. I have that combo and love it.
So i guess i would have to do the mini-truck 79-85 conversion to add the longfields and at the same time gain disc brakes.Or can i just upgrade the birfields to a fine spline with the existing set- up? and then add the aussie.
You cannot use disc brake birfs/Longfields with US pre-08/76 drum brake spindles/wheel bearing hubs, etc. You must convert to disc brake components from a Mini, or preferably, from a 60 series, as they have larger, vented rotors.
Lots of reading in the FAQ on this topic.
:beer:
You are the man!:cheers:
