Best source for low cost (right) rear wheel speed sensor?
Hi,
I got the ABS, Brake, TRAC warning lights, searched here, jumpered the diagnostic plug, counted the flashes, looked in my FSM - looks like the right rear wheel speed sensor is malfunctioning.
I need to swap it out. I know when I used to be more active here CDAN was the go to for OEM, but I don't want to spend OEM money. Poking around on the web, I see aftermarket ones for $140 and up (Rock Auto).
Also any tips on replacing it? I know I can figure it out, but if you've "been there, done that" and can share any tips or advice, I'd be appreciative.
Any suggestions?
Thanks!
PS. I forgot to mention that this is a 2001 100 series land cruiser, in case it matters.
I purchased the wheel speed sensor from RockAuto with the ih8mud coupon, it came in two days. I swapped it out, reset the system (jumper Tc and E1 in the under hood diagnostic connector, turn ignition on then tap brake pedal 8 times or more in 5 seconds). All is good with the world again. In my case, sensor removal was destructive because it was stuck in place.
