Last set was purchased from sor, any other sources?
I think BAP can get them, and in my experience with with BAP their brake parts seem to be high quality.
^^^ Agree, some of the brake/clutch hydraulic parts that I have used from them appeared to be OEM with the name machined off.
I've got to pull some drums this weekend, any idea where BAP sources them from?
Nope, don't think that I purchased '40 cylinders from them, just good luck/result with other Toyota cylinders from them.
What is the problem with yours? If not scored, badly corroded, just kit them?
I've had a lot of success with putting them on the ends of my axles.
I have all the brake components from my 68 that are no longer used. For that matter, I removed most of the brake lines from the front end this evening. Most everything on mine was replaced back in 2002 or so and has been working as well as drum brakes can since. The single res. master is pulled out and all the wheel cylinders are still on, but could be pulled off.
Cylinders, not Spinners..
You need some more crawling around in the dirt time.
I have an extra dual reservior if you are interested. Looks to be in pretty good condition but has no caps (at least not good ones).
PM me
Update, and kinda bummed...
Pulled drums today, and it was the new aftermarket sor cylinders that failed (replaced last year). The rebuilt oems with kits from Merles on the left side are ok..
Shelf life issue?
If not rust pitted, put new seals and go?
