I have a brand spanking new set of OME light springs for my '76 FJ40. They are the CS001F (front) and CS001R (rear). ARB claims 1.5" lift in the front and 2.25" in the rear from these springs. I'm also using some anti-inversion shackles that are close to stock length.
I'm planning to remove a leaf from each spring in order to get closer to a stock ride height.
So that's the first question: will removing a leaf from the light springs reduce the ride height at all? Or will it just soften the ride?
I removed the 4th from the top of the front springs. Some threads have said remove the 3rd from the top, but it has a clamp attached so I removed the 4th from the top instead. This spring originally had 6 leafs, so that left me with 5 which seems fine as far as I can tell.
Here's the second question: the rear springs I got had 4 main leaves and 1 load leaf. I removed the 3rd from the top, but then only 3 leaves are left. Is that right? Seems like awfully few. Or would it be better to remove the load leaf?
Last question: I'm also wondering if I somehow received CS001R springs that were already missing a leaf. Do they really only come with 4 leaves + 1 load leaf?
