- Year
- 1999
- Vehicle Model
- 100 Series
- Mileage
- 177000
- Color
- rgb(0, 46, 1)
I am selling my 1999 Toyota Land Cruiser in Imperial Jade Mica that currently has approximately 177,000 miles. It is a poverty pack 100 series and is equipped with factory cloth seats, no sunroof, no third row seats, and no an OEM rear differential locker. It also has solid rear cargo area windows (no tilt outs).
$17,500
I purchased it in February 2019 from a gentleman in Nashville, TN that had owned it since 2004 when he purchased it from the original owner in Houston, TX.
Modifications include:
BF Goodrich KO2 tires (11/32" tread depth)
Upgraded rear suspension (Front OEM and rear Tough Dog 41mm shocks, Old Man Emu 2866 springs)
Rock sliders with kickout
Rear drawer (Land Shark Outfitters)
Fridge drawer or fridge with slide (can be configured to your taste or removed altogether)
Dual battery with DC/DC charger (RedArc)
Air compressor (ARB)
12,000 pound winch (Smittybilt X20) and wireless controller
Rear tire carrier (Kaymar)
OEM rear diff locker
Load bars on roof (Eezi-Awn)
Escape Gear seat covers
Professionally re-leathered steering wheel
Original listing photos are located here: Link to Photos
The truck isn't perfect but I think it's pretty good. Maintenance/baselining work was performed at a local Land Cruiser specialty shop, State Automotive. I've handled the little things (D-light bulb, sway bar bushings, air filters, cleaning, etc.)
The good and history:
The bad:
$17,500
- TX and TN for 19 years
- Most everything underneath in the photos that's red is Southern Utah sand and not corrosion
- All original VIN (JT3HT05J9X0026798) stickers throughout
- VIN etching on all windows except passenger front (vandalism)
- Service records or history from 26k miles showing routine oil changes and other appropriate maintenance
- Notable prior service:
- Starter at 69,000 (8/25/2005)
- Timing belt, ignition coils, spark plugs at 90,174 (9/21/2007)
- Radiator, steering rack, and charcoal canister replaced at 155,259 (7/7/2018)
- Service/modifications under my ownership:
- 12/32"+ BFG KO2 285/75r16 installed at 161,925 (4/5/2019) (4 used, 1 new)
- All fluids (coolant, diffs, transfer case, power steering, brake) replaced at 161,947 (4/25/2019
- Wheel bearings replaced and repacked at 161,947 (4/25/2019)
- CV axles replaced at 161,947 (4/25/2019)
- Alignment at at 161,947 (4/25/2019)
- ARB 37" roller drawer/roller floor installed at 163,690 (5/30/2019)
- Slee second battery tray, Optima Yellow, ARB compressor, and Redarc BCDC1225D, ARB fridge at 163,839 (7/13/2019)
- New AC Compressor, drier, fan clutch, and alternator at 164,417 (9/9/2019)
- Valve cover gaskets replaced with PCV, new bolts, etc. and several new hoses at 165,287 (1/18/2020)
- Fuel filter replaced at 165287 (1/18/2020)
- Muffler replaced with OEM-style Magnaflow at 166,680 (3/6/2020)
- Replaced driver door lock actuator motor at 166,841 (3/25/2020)
- Custom weld-on sliders installed at 166,858 (4/9/2020)
- Timing belt and water pump at 168,448 (8/21/20)
- Oil analysis: Blackstone Oil Report Repository - Share Your 2UZ Reports - https://forum.ih8mud.com/threads/blackstone-oil-report-repository-share-your-2uz-reports.1232643/
The bad:
- There is an area to the rear of the rear passenger door that was damaged and repaired by the original owner. The second owner was unaware. It was repaired back then but it appears that the steel to filler bond has failed. There's a video linked in the photo library below showing the damage and the extent of the filler. I've since repaired some of it. I have a dog-leg cutout from another '99 that can be used for a repair.
- Paintless dent repair evidence from "accident" on Carfax. Previous owner said it impacted the driver side, mostly under the side belt plastic trim. You can see some areas where it didn't get back 100%, but there is no evidence of door skin replacement and all VIN tags are present.
Front bumper rubs on passenger side fender where some bump was sustained (pushing the bumper into the fender and not pushing the fender down)No longer rubbing but the paint is a little weird here- Little ding below the passenger side tail light on the body
