Started the car today and I had my battery light turn on. When I started to give it gas, the speedometer dropped to 0 the AC started blasting, all the dash lights turned on. If I let off the gas, the speedo jumps back up and then the lights turn off. I got a P500 vehicle speed sensor fault code, which I would think is more of a symptom than a cause. Battery voltage was 12.9 resting 14.4 at idle and jumping up to 18 plus when I give it gas. I'm guessing a voltage regulator is bad? Alternator issue?
