ARCHIVE Barnes 4WD Solid Axle Swap Kits
Barnes 4WD Solid Axle Swap Kits​
Our axle swap combos are the best of the best, with these combos you will be saving a 10% off our all ready low prices. When it comes to changing axles in a leaf sprung rig you want to get it right the first time, and forget about it. Like all of our products, they are made in the USA from USA steel. These combos include all the parts that you will need for your weekend axle swap.
• Four 10" x 5/8" U-Bolts with Tall Nuts and HD Washers
• Two Spring perches
• Two U-Bolt Plates
• Two Bent Axle Shock Mounts
Some kits do vary to fit you specific application. If you would like to exchange a item for one of a different size just let us know.
SUA Swap Combo
AAM11.5 Dana 80 Dana 70HD Axle Swap Combo
Dana 30 35 Axle Swap Combo
Dodge Kingpin Dana 60 Front Axle Swap Combo
Ford 9" Axle Swap Combo
Ford 8.8 Axle Swap Combo
Dana 70 & Ford Sterling Axle Swap Combo
Ford Kingpin Dana 60 Front Axle Swap Combo
GM Kingpin Dana 60 Front Axle Swap Combo
Dana 60 Rear Axle Swap Combo
Dana 44 Axle Swap Combo
Toyota Rear Axle Swap Combo
14 Bolt Axle Swap Combo
