What does a bad pilot bearing sound like? On my swap, I have had a rattle sound from the clutch area since day one. Never has got worse or better.
I used all new clutch, pilot and throwout bearings and flywheel.
When I start her up and everything is cold no noise, after driving noise starts. Happens when stopped or moving as I tried transfer case in neutral test. I can some times stop or minimize the sound by pushing the pedal and releasing the clutch a few times quickly. The sound goes away every time the clutch is engaged (Pedal pushed in) and held there and comes back when released.
I have thought it was the transmission input shaft free spinning, possibly due to more vibrations from the diesel engine? But I came across a post on another forum about a bad pilot bearing making this type of sound.
The pilot bearing, Advance Adapters Chevota, was new and made this sound from the first drive.
What do you think? I have never had a bad pilot bearing before.
Thanks
Doug
Thanks
Doug
