I've had a squeak for quite some time now. It seems to come and go, but I have not been able to narrow down the cause. The squeak is coming from the pad rubbing the rotor every so slightly, and only in one spot on the rotor. Rotors are not warped, they are smooth and quiet. I had them super hot towing a boat and they have no uneven deposits either. So, the pads are clearly not fully releasing from the rotor as fast as they are supposed to. After a few mins of driving, they release and the squeak goes away. Oh yeah, pads are fine. Lots of life left.
Could this be a frozen piston in the caliper? Or could that be a sign that the MC is not working right? I flushed about 75% of the old fluid out w/ new Dot 4 sythetic, bled the brakes on all 4 corners, and problem is still there.
Thanks for any help!!
If it turns out to be calipers, I may be in the market for new calipers and some yellow stuff pads!!!
