I recently finished a BJ40 project and am selling all my extra parts. Im not completely up to speed on the values for this stuff but would sell everything for $5k if someone came and picked it up. Value of everything selling it piece by piece Im guessing would be over $10k, but honestly Im not an expert. I can send pictures upon request. Would rather sell all at once but if that doesn't work I will piece out. Everything is used unless noted.
noted | qty | |
H41 Transmission and Transfer case | ||
H41 Transmission and Transfer case with brake drum | ||
Fan Clutch | ||
Cylinder Head, Australian large valve, complete with valves/springs, still in plastic. | new | |
Air Cleaner Assembly, paper element | ||
Vacuum Canister | ||
Flywheel | ||
radiator screen, FJ because no extra tabs for Diesel logo, not sure of year but its original and in great shape. | ||
camshaft, 3 bearing | ||
Engine block 11411-56020 | ||
thermostat housing and neck | 2 | |
valve covers, 1B-64 decal on one, the other is polished | 2 | |
injectors, checked for operation at diesel shop. | 8 | |
cylinder heads, dissembled, all parts. oem 11111-56020 | 2 | |
cylinder head bare, oem 11111-56020 | ||
alternator with vacuum pump, no tags | ||
engine fan with clutch, Asco, 7 blades, Blue base | ||
engine fan, 8 blades, not fan clutch style. | new | |
Fan with clutch, ASCO cast in clutch and fan, 7 blades, black base color | ||
edic rod | 2 | |
injector return line | ||
exhaust manifold | 2 | |
edic motor 12v, 28571-56120 | ||
timing gear set, used, appear to be in good condition | ||
diesel injection line | 8 | |
injector return line | 2 | |
push rods, appear to have little wear, 256MM in length | 16 | |
oil pan | ||
air cleaner, paper element | 2 | |
oil filter housing, downward facing | ||
power stearing pump and bracket, 44443-60060 B2DA. Pump 60020 | ||
front timing gear cover and oil pump | ||
intake manifold | 2 | |
intake butterfly valve | 2 | |
starter 24v, ND 028000-5550. Toyota part 28180-56070 | 2 | |
gasket set -oil pan and timing cover missing. Teikin Oem #04111-59012 | new | |
edic motor 24v, 28571-56050 | ||
injector pump, ND 190000-1032 | ||
pistons and rods set, used, ART on skirt, 56013 inside, Toyota logo cast | ||
rocker shaft | 2 | |
Misc nuts/bolts/brackets/head bolts | ||
Cam bearings, new 5, Clevite 77 SH-1481S | ||
Short Block (Assembled) | ||
24 v alternator, ND 100210-1401 Toyota 27030-56032 | ||
24 v starter, no markings, assume its 24V | ||
24 v edic | ||
pistons and rods, still in block, not inspected. | ||
crank, still in short block, have not inspected. | ||
pressure plate | ||
camshaft and gears | ||
fly wheel | ||
oil filter housing is downward facing, filter screws in from the bottom | ||
fuel filter housing, has used filter 23303-56031 | ||
injection pump, ND 190000-1032, 1050772, toyota 22100-56161 | ||
pullys | ||
oil pan |
