I swapped over a set of fine spline birfs, knuckles and calipers from an axle I had purchased a few years ago. As a result, I have a few leftovers which will hopefully help recoup my costs and be of assistance to someone else.
Make offers. I dont feel like researching.
Coarse spline birfs/axle shafts
Axle housing
3rd member
Also, I have a hard top which will need to have the fiberglass pulled off and re-installed correctly. I did some bubblegum work on it and you will probably want to pull it all apart. After putting it back together, I should have installed the sides and back on the tub and then put the top on so that it will fit. Instead, the top is too far back, about 1/2 inch and wont line up with the windshield frame.
Make an offer.
Thanks,
Rob
Axle housing
3rd member
Make an offer.
Thanks,
Rob
