Axle rebuild help. How badly did I screw up? (1 Viewer)
Caliper bolt fell out on me after doing bearings birf, and seal RnR. I have a 1997 LC. Is 12mm x 1.25 x 40mm the correct caliper bolt? Takes 12mm wrench/socket on bolt head?
If I remember correctly I zip tied my calipers to my springs to keep them away and not dangling on the the hose. I just kept the caliper bolts in the calipers; there's enough grease to keep them from moving about. In a youtube I watched someone told me to be careful about mixing them up, so that way they just stayed up there until it was time to put the caliper back on. I took them out, heat them with brake cleaner and badda bing.
Yep, here's a picture. The bolts hung out for three days while I worked on it.
I knew I was going to be worried about having leftover parts and had to span multiple days further depleting my short term memory. I used an egg carton and sharpie. Placed them chronologically, reversed order. FWIW.
