Based on averaging this 5 mile round-trip per day how often should I take an extended drive to keep the LX 570 loosened up and working correctly?
The Valvoline water figure is incredible if not all most impossible to believe? At 12MPG thats 400 plus gallons of fuel produces 2K gallons of water. I believe their figures to be off by a bit? I know our ethanol based fuels in Ca. suck but not that much.All depends on how long your motor has at operating temperature.
When a motor is turned off and fully cools, it creates condensation inside and that water sits in your oil sump. When you fire your motor back on, heat will burn that water off. The issue with short tripping is that if you don’t get your motor at operating temps for long enough to burn the water off, then you simply keep adding more water to your oil. This “thins out” your viscosity along with a whole host of other things that would take us down a rabbit hole. I’m not using the corrects terns right just to make it simple for everyone.
I remember a while ago, reading a study from Valvoline where they found the average motor, over a 5,000 mile oil charge, would see 2,000 gallons of water come and go in the sump.
There are two really great ways to prevent damage from short tripping. 1) don’t 2) change your oil more often.
Simply send off your oil for analysis and you will know, based on your motor and the conditions you are putting through, how much oil life you are getting. That will tell you when you need to change. After some time, you’ll build some averages, and won’t need to do oil analysis that often.
Inside an ICE is a pretty crappy place. It’s very acidic, and filled with deposits. Oil is not just for friction mitigation but it also does a majority of the cooling from heat transfer. Not to mention regulates valve timing (at least for our 5.7s with hydraulic lifters. Oil is cheap, land cruisers and their motors are not.
People get all weird about 20 weight oil. But oils today are sometimes more robust than they used to be (sometimes). Yesterday’s 30 weight would shear more easily down to 20 weight, but people slept good at night because they didn’t know. So don’t go down a road of trying a more robust oil viscosity. While minute, the thinner the better for all the start ups you are putting that motor through.
But the same still applies today. All you need to to do is ensure you don’t have oil that has fallen out of grade in you motor. Easy.
Easy things like the battery not getting charged back up enough are mitigated by a good charge once a week or so. I like CTEK chargers personally.
I was pretty shocked myself. And to this day, I have never found another study that had anything like that, and who knows if I'm remember incorrectly or not as it was a while ago.The Valvoline water figure is incredible if not all most impossible to believe? At 12MPG thats 400 plus gallons of fuel produces 2K gallons of water. I believe their figures to be off by a bit? I know our ethanol based fuels in Ca. suck but not that much.
Then you have solid setup right now. It might be a short mileage trip, but you are getting the motor hot enough during that short time to not cause any issues.My last well analysis 7000 mile oil change interval shorter trips
It’s full synthetic Kendall 0W 20Swutah
Are these oil changes completed at your lexus dealership? Did they use Phillips Full Synthetic motor oil?
