Automatic Transmission Temps.
Gun Runner 5
ODD IRON OFF ROAD
Ochlocknee, GA
Any opinions on what would be considered normal operating temperatures for a Toyota automatic transmission? (City traffic, ambient temps. in the 80-85 degree (F) range)
Thanks
various automatics have always yielded 180-185F range at speed for me, (corolla, taco, sentra etc) I cant see it deviating too much from there. 190 when its hot with AC on, if it starts hitting 200-210 is worry, 220 is fire
Thanks Andrew. I've been seeing 150-180 degrees in city traffic and the temps. didn't change much when I had the transmission flushed recently.
Charles, found this old thread, im sure there are folks smarter than me on this, but i dont agree on temperatures talked in it,
A440F Operating Temp...
Ive been taught that heat kills auto trannys, period, under 200 is the goal. This chart backs up what i believe. Again, there may be folks way smarter than i in this. I subscribe to anything over 220 is an asap fluid change as well.
154 1203 04+temper Tantrum+transmission Life Expectancy Chart - Photo 39657948 - Automatic Transmission Temperature Monitoring
154_1203_04%2btemper_tantrum%2btransmission_life_expectancy_chart
Thanks Andrew......
The transmission has lasted 27+ years so hopefully it will continue to do so. I wonder how many people actually have mechanical gauges that monitor the tranny temps. vs the dummy light forward of the shifter.
Hello Charles/ @Gun Runner 5 ,
From the factory manual: 70 - 80 C or 158 - 176 F.
The manual also says that the throttle cable must be inspected after checking oil temperature.
The manual strongly advises not to exceed the specified range.
Close the throttle valve. Measure the distance between the end of the cable boot/jacket and the stopper. It should be less than 1.5 mm / 0.059 in.
Open the throttle valve. Measure again. Distance should be 32 - 34 mm / 1.260 - 1.339 in.
Hope this helps.
Juan
Thanks Juan.
City traffic, high 80's (F) ambient temperature ...... Approximately 150-160 degrees.
