I'm thinking about installing an rear Aussie locker on my 1997 FZJ80. What would the average install cost be from a mechanic and What is the difficulty level if I ended up installing it myself?
Thanks
Thanks
me too. i put arb lockers on my christmas list but if i dont get them i plan on buys a aussie locker for the rear. im worried because ive never pulled the rear apart on anything.I'm thinking about installing an rear Aussie locker on my 1997 FZJ80. What would the average install cost be from a mechanic and What is the difficulty level if I ended up installing it myself?
Thanks
I installed an Aussie locker in my ff rear axle with out issue. I never did any work on my own vehicles before my 80 so it must be pretty easy. I had stock gears at the time but I'm not sure what difference that makes.
It makes a difference because anything over the stock 4.10 and possibly 4.56, the ring gear gets thicker because the pinion gets smaller, therefor you have to take the ring gear off to take the crosspin out. At that point you need special tools to reset backlash etc...
Well that would make a job pretty much anybody could do much more difficult. I could not have done it on my owne if that was the case. Am I remembering incorrectly or have people shaved the very inside of the ring gear teeth to get around this problem?
tpham32 said:I have a quick question. I too have a 97 and was thinking about an aussie locker, but heard they will not fit with a LSD carrier. 97s have LSDs right??
I don't think any of the 80s came with lsd's. Either e-lockers or open carrier as far as I know.
