So i was looking over the old thread Dave started years ago about his 80. Fast forward to now, and i was wondering what to do about the front suspension of the 80.
I have taken out the OME heavys and spacers front and rear and am replacing them with OME 861/862 springs. So this is going to put my castor way far the other way correct? When you typed Forward arm mounts have been changed.. what does this exactly mean? and can it be undone? I noticed the bolts are welded onto the LCAs. was this done to correct castor? I see it has the yellow bushing, so in theory if the arm was unmodified i should be right where i need to be for castor....
Does this make any sense? do you even remember what when on with that rig so many moons ago?
I'm still in process of putting it back together so i can't just go get the castor checked, so i thought i'd ask the question while its all still apart..
thanks!
Jon
Original post :
Dave
IIRC that truck has spacers in front for sure
not rears?
front spacer levels MAF 4 inch kit
front axle has bushings and also forward arm mounts have been changed for caster,
which is why it handles so well.
it is a tad tall tho....
just toss some 37 inchMTR's on and go
thanks!
Jon
Original post :
Dave
not rears?
