- Year
- 1989
- Vehicle Model
- 60 Series
- Location
- ATLANTA, GA 30324 United States
- Mileage
- 171000
- Color
- Gold
Serious buyers know how rare it is to find an FJ62 with documented care, thoughtful upgrades, and consistent mechanical stewardship. This 1989 Toyota Land Cruiser (VIN: JT3FJ62G4K0097912) is exactly that vehicle — a well‑preserved, tastefully updated classic with 171,000 original miles and a maintenance history that speaks for itself.
This truck has been owned by someone who prioritized reliability, OEM parts, and long‑term preservation. It runs beautifully, drives confidently, and is ready for many more years of dependable service.
- 171,000 miles
- Excellent mechanical and cosmetic condition
- Extensive documented maintenance
- Transmission & transfer case professionally rebuilt at 169k
- Kenwood head unit with Apple CarPlay
- LED headlights, upgraded wiper arms, sound deadening, and more
- Cold A/C, strong heat, smooth shifting, tight steering
- Clean interior with upgraded seat foam and dash top
- Turn‑key, reliable, and ready for daily use or collector ownership
Below is a curated summary of the most valuable work performed. Full detailed log available upon request.
2025
- Greased U‑joints and driveline service (170,500)
- LED headlights installed
- Speedometer cable replaced
- Tire rotation (169,807)
2024
- Transmission & transfer case rebuild (169.7k)
- New OEM oil pan & gasket
- Front knuckle rebuild
- OEM shocks (front & rear), sway bars, links, bushings
- Tie‑rod end & rubber bushings
- OME steering dampener (168,550)
2023
- New hood‑to‑cowl weatherstrip
- Roof repainted; rear left fender repaired; all dark brown trim repainted
- New battery (2‑year warranty)
- OEM air cleaner intake hose kit
- New rear lift‑gate supports
2022–2021
- Upgraded 4Runner wiper arms
- Front seat foam replacement
- A/C recharge
2020
- Mishimoto aluminum radiator (166,528)
- Oil change (165,145)
- Second Skin sound deadening applied to all doors & floor
2019–2017
- Transmission shifter bushings
- Oil changes
- New tires
- 4WD solenoid
- Front & rear brakes, caliper, differential seal, horn repair
- New battery (3‑year warranty)
2016–2013
- Wheel alignment
- Weatherstripping
- Window tint
- Dash top
- Front bumper caps
- New speakers
- Aftermarket antenna
- New muffler (153k)
- New battery
- JVC Bluetooth receiver
2012 (Major Refresh)
- All hoses, radiator, water pump, thermostat
- Belts, valve adjustment, motor adjustment
- Throttle body cleaning, evap check
- Front axle rebuild
- Rear brake adjustment
- New mirrors, lift‑gate struts, shifter bushings
- Kill switch installation
- New brake calipers & pads
- A/C service
- Weatherstripping
- Purchased at 149,916 miles
- Upgraded speakers
- Sound‑deadening throughout cabin
- Fresh seat foam for improved comfort
- Clean dash top and interior trim
- Cold A/C and strong heat
- Repainted roof and refreshed trim
- New weatherstripping in key areas
- Strong 4WD system with recent solenoid replacement
- Smooth shifting thanks to full transmission/transfer case rebuild
- Solid steering with OME dampener and refreshed bushings
- New shocks, sway bars, and suspension components
- Tire pressure: 35/35 (30x9 50r15lt 104s)
This Land Cruiser isn’t just maintained — it’s curated. Every major system has been refreshed, rebuilt, or upgraded with longevity in mind. It’s a rare opportunity to own a classic Toyota that’s been preserved with care, documented thoroughly, and kept in excellent running condition.
If you’re looking for a clean, reliable, and well‑sorted FJ62 with a long life ahead of it, this one deserves your attention.
Reach out to schedule a viewing or request the full maintenance log.
