- Year
- 2006
- Vehicle Model
- LX470
- Mileage
- 180000
- Color
- Black
2006 LX470 with 176,000 miles. Two owner Florida car with virtually no rust. Located in Fayetteville Arkansas.
Truck is overall in very good shape mechanically and cosmetically. I purchased a year and a half ago with the intent of having this be a winter vehicle in Michigan. However, we moved to Arkansas last summer and I’m planning to move on to something a bit more sporty.
Only spent two winter months in MI and undercarriage was cosmolined prior to it seeing any snow.
While I’ve done quite a bit of baselining since purchasing, there are still a few things left to get it to perfection noted below.
No lien, title in hand.
The following has been done under my ownership:
The truck would need the following based on a recent inspection:
Extras coming with the truck:
- BT45TOY installed
- Five new Michelin tires and new TPMS sensors (11/23)
- Low and high beam bulbs (10/23)
- Driver’s side AHC shock replaced (7/23)
- Differential mounts replaced (5/23)
- Steering wheel re-wrapped (original wood still underneath) (5/23)
- AHC globes replaced (5/23)
- Transmission fluid replaced (9/23)
- Front and rear Differential fluid replaced (5/23)
- Transfer case fluid replaced (5/23)
- Sway bar links and bushings (5/23)
- Steering wheel telescoping motor replaced with OEM unit (11/22)
- Mid-range and subwoofer speakers replaced (10/22)
- Brake fluid flush is due
- Both CV shafts due for re-booting
- Power steering hose is weeping
- Passenger side AHC shock or o-ring needs replaced
- Antenna goes to half mast (I only use BT, so don’t notice)
- Headlamp covers have cosmetic cracking
- Drivers side armrest leather cracking
- OBD to USB cable for techstream
- Original floormats
- Drivebelt
- Engine and transmission mounts
