Are the seat back positions too low?
Centennial, CO
Does anyone feel like the most vertical position on the front seat (specifically drivers for me) is too leaned back? I know that's popular for lots of people, but my back enjoys sitting more upright. I feel like when I have the seat at its highest position, I'm still leaning way back....
If you are talking about your 77, I feel the same way. While they are comfortable, they never do feel quite right.
Not sure how the 77 seat mounts, but you might be able to build a riser for the rear to lift it up and make it more vertical.
That's what I was thinking, my only hesitation is how high it will be raising me up/my seat bottom angle to get me to that point. I think it would take quite a bit ha. I'm going to pull some of the seat assembly apart and start seeing what might be an option to just adjust the back.
Getting rid of the suspension bases (if possible) would probably give you a lot of working room.
After a little disassembly yesterday, I’m less hopeful about modifying the positions ha. The splined area would be difficult to duplicate, and it’s all riveted on there. There are 2 bolts on the bottom seat pan, and 2 on the upper seat back. I think easiest (not necessarily easy) would be to unbolt the top, and add an starter to move the seat back forward. The bottom bracket would be harder to do that while maintaining the same fulcrum point in the hinge. Something to brain storm a bit.
