Recently picked up a 100 series with an ARB Twin Compressor installed; I believe the model number is CKMTA12. It appears to also have a VERY small aux air tank on it as well, which I seem to recall the PO pointing out to me.
Question:
The compressor seems to run at start up no matter the position of the in cab switch, and also periodically if driving for a while. I assume the compressor is running to top off the small aux tank.
Is this the normal way to install these compressors?
I was under the impression they were typically installed to be 100% controlled by the in-cab switch. The vehicle does NOT have lockers, so needing to always have a bit of air in the aux tank seems unnecessary.
Question:
