ARB twin compressor in engine bay
duggy
Houston, Texas
I currently have my ARB Twin Compressor mounted in the engine bay but since the engine heat and output heat are pretty high, the lines I have been using cannot withstand the high heat. What have you guys been using to air up tires from the output of the compressor? I already have a tank mounted in the rear so the main concern is how to dissipate the heat coming directly out of the compressor.
You could use some copper tubing to make hard lines far enough to get away from the heat. Compression to pipe thread fittings and some roll copper tubing is easy to get and easy to manipulate by hand and comes in any size you need, 1/4", 3/8", 1/2", ect...
