Measure 3 or 4 times, cut once is my mantra here. I'm installing the ARB Summit on my 2016 Land Cruiser. Following both FSM and ARB directions. One area that I wanted to confirm was the placement of the template.
The ARB directions say to line up the wheel well and left side with the fender edge. (Very easy to do.) They also suggest making a small vertical cut in the top of the template to allow it to bend with the bumper. Again, I get that.
However, I wanted to just triple check that it is the bottom edge of the template that must be flat against the bumper, like shown. (Opposed to aligning the top edge of the template along the bumper edge- that actually brings the template vertically up a bit and not perpendicular with the headlight washers.)
I oriented the template beginning on the left w/ the 2 pieces of tape to hold it. I then ran my finger along the bottom (cut line) edge of the template to keep it perfectly flat along the curve of the bumper. That resulted in the right edge of the template end up where you see it, about 1/8" below the headlight washer, where i secured it w/ another piece of tape.
It looks correct to me but I just want to be paranoid a bit here. The small pictures in the ARB install directions are... very small.
Do you guys see any concerns here or does it look correct?
thanks!
thanks!
