ARB leak question?
For those that have had this problem please let me now what you did to have this fixxed. My solenoid for the rear air locker is leaking a small amount after a drive. In the past I read similar problems about ARB lockers but now that I am having the problem I cant find the threads on the search program.
What causes it and how is this fixxed are my main two questions.
Thanks
Stephen
and where exactly on the solenoid is it leaking (in or out)
there are rebuild kits that you can get for them with new O rings and such
gear lube is leaking out from the bottom of the solenoid. I have the solenoid run to the slee manifold for a cleaner look as well as having capability to run the accesory plug off of it. Anyway I am getting a few drop out of the bottom of the solenoid each time i drive the truck. Not sure what the cause would be or the fix to it?
steve :mad:
I will check that out! i hope that is all that is wrong with it!
I haven't had the locker installed, but for a month or so!
would there be any other things it could be?
Thanks
