Ended up buying a Exide group 27 deep cycle with 105 amp hours. Should be plenty for my needs.
Just use a hot glue gun to fix the baterry.pretty simple safe fix.
How did you break the case?
The marine batteries are said to be built to take speedboat pounding. Was it an auto or marine battery that broke?
What the fudge is the difference between 2x 6v and 1x 12v?
I use 2 x 12V on my FJ and 2 x 6V on my trailer for just under 500Ah total which makes for a nice long weekend with cold beer
Probably because some of us have more power needs than just an ARB fridge.![]()
So what power requirements do you have in mind ??? 900 watt microwave, sattelite TV, washing machine ?? - you can feed the solar into a RV battery bank for larger peak power requirements while your starting batteries are alway protected and kept fully charged.
That is exactly what I plan to do Glenn. I am pretty sure my CPAP draws a lot more power than a fridge and that is if I do not use the humidifier function. The max off grid for me would be 3 days for the CPAP alone. This I have tested with my 110 AHR third battery.
