I decided to go in the direction of rediculous (cuz I can
). After I replaced the two lower lights with HID's from Checker (so far so good), I realized that I had a handful of extra lights laying around, I thought of adding a pair to the top tabs but didn't like the look. Then I lined up all of my spare lights on the ground and thought, why not make a light bar? I used a piece of DOM I had, capped the ends, drilled wholes that matched the top tab locations and welded in threaded rod. Added tabs for all six lights then sent it to powder coat. Obviously I didn't want this on full time, so I made it removable. Using two marine four port doc plugs, I wired all of the positive leads for each pair to a relay pack, and all of the negatives to a local ground. Painted one red and one black (for obvious reasons), and fab'd a little bracket that attaches to one of the horn tabs under the hood. On/Off = two nuts and two doc connectors to unscrew under the hood, easy. Also used a four button switch pad that autozone sells, fits perfectly where my factory locker switch should be (I like my ARB switches where they are
) The lights are as follows: 2 Checker HID, 2 Hella Rallye 2000, 2 Hella Rallye 4000, 2 KC Daylighters (angled out to light up the sides).
Before the flaming begins, yes I know it's pointless, no I don't drive this truck off-road fast enough to really NEED that much light, yes I realize it has a negative impact on MPG
. As I said in the beginning, I just did it cuz I can. Plus my camping buddies say it looks like a space ship is coming through the forest.
