Hi all
got ARB front bullbar without a Winch on a reasonable price. Just thinking if i can put it with Stock Suspensions.
I own 1998 Amazon with height control.
regards
Mubashir Keen
You will have to consider cranking the torsion bars. The extra weight will bring the front down too much. Just install winch and bumper, and crank bars back to the level prior to the installation.
No issues. The bumper doesn't weigh all that much but like mentioned above, you could give the front a little help by cranking the tbars. From a weight issue though, the stock suspension will handle the weight just fine.
Measure your fender lip to wheel center distance on both sides of the front before pulling your OEM fender off and crank the t-bars back up to the same height when the ARB is on. When done, you should be about .75"- 1" rake down from the rear to the front as measured at all four wheels to fenders.
Amazon with height control.......Height is automatically set by the AHC height sensors so OP you just need to consider adjusting your torsion bars to compensate for the increase in hydraulic pressure (neutral pressure) the extra weight will induce.
