Hello! I am looking at purchasing a 62 and am curious about some high level costs on repainting it and some rust repair. The truck is not local to me. Here is what Gemini told me. I’ll attach some pictures. I tried using the search function and couldn’t track down anything in particular.
Repainting a classic 1988 Toyota Land Cruiser FJ62 and tackling rust is a major project, especially since the 60-series is notorious for developing rot in those rear quarter panels. Because you want to match the original factory color, you'll save a bit by not needing the engine bay or interior jambs fully stripped and color-swapped, but the rust repair will be the biggest wild card.
Depending on the shop rate in your area and the depth of the restoration, here is a breakdown of what you can expect for different levels of quality.
### 1. The "Driver Quality" / Basic Respray
**Estimated Cost:** $4,000 – $7,000
This level is for someone who wants the truck to look good from 10 feet away but isn't building a show car.
* **The Paint:** The shop will do a basic "scuff and shoot." They will tape off the glass and trim rather than removing them, which can sometimes leave visible tape lines.
* **The Rust:** At this price point, shops often grind down the surface rust, treat it with a rust converter, and use body filler (Bondo) to smooth out the quarter panels.
* **The Catch:** Bondo over rust is a temporary fix. Moisture will eventually get behind the filler, and the rust will bubble back through the paint within a couple of years.
### 2. The "Enthusiast" / Mid-Level Restoration (Most Common)
**Estimated Cost:** $8,000 – $15,000
This is the sweet spot for a classic Land Cruiser that you want to look fantastic and last for decades, while still actually driving it.
* **The Paint:** The shop will remove the trim, bumpers, lights, and likely the windshield and rear glass to ensure paint gets fully into the channels. They will block-sand the body to ensure the panels are straight and use a high-quality two-stage paint (base coat and clear coat).
* **The Rust:** The rusted sections of the rear quarters will be completely cut out. The shop will weld in replacement steel patch panels. *Note: Companies like Cruiser Corps and Alfa Parts sell pre-formed rear quarter patch panels for the FJ62 for about $200–$275 per side, which saves the shop expensive fabrication time.*
* **The Catch:** Once they cut into the outer quarter panel, they often find rust on the inner wheel wells or structural supports, which can quickly add hours of labor.
### 3. The "Show Quality" / Bare Metal Restoration
**Estimated Cost:** $20,000 – $30,000+
This is for a museum-quality, Bring-a-Trailer ready restoration.
* **The Paint:** The truck is completely stripped down to bare metal via media blasting or chemical stripping. Every minor dent is pulled, and the body is meticulously block-sanded perfectly flat. After painting, the clear coat is wet-sanded and polished to a mirror-like, flawless finish.
* **The Rust:** Any rust, down to the microscopic level, is eradicated. Entire panels are replaced if necessary, and inner cavities are heavily coated in rust preventatives like cavity wax.
* **The Catch:** You will be paying for hundreds of hours of highly skilled manual labor, and the truck will likely be in "paint jail" at the shop for many months.
Because rust is like an iceberg—you usually only see the tip of it until you start grinding—the final bill can fluctuate wildly. Are you aiming to restore this FJ62 as a pristine investment piece, or are you looking to build a clean, reliable driver that you can still take on the trails without stressing over a new scratch?
