Anyone ID the reverse lights (2 Viewers)
RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Nahant Ma.
Website
www.youtube.com
I bought LED reverse lights as mine died and these are what I found no numbers nada
The top ones look like what sells everywhere as a generic 1156 5w or 7w Cree bulb. I’m not sure about the bottoms.
bottoms are what the LC called for, top is what I found when i pulled the tailight
got em, ordered the resistor too, I hate hyper flasher. thanks guys.
You don't need a resistor for the reverse lights. In fact, you don't need one for the turn signals either if you convert those to LEDs. There's a flasher relay that SBL sells that works with LED turn signals. I experienced an issue with my LED conversion that required one load resistor on the left brake light, but that's all. I've done a full conversion minus the headlights so feel free to PM me if you have any questions
when i bought the truck it had halo headlights, I swapped in dpeos and then the flasher got wacky on me.
Advance Auto stocks the Novita EP36 flasher relay that is plug and play by drivers foot. That should fix any issues with flashers.
BTW. you can make some KILLER bright versions for cheaper than pfrans or whatever the parts store sells.
XML-2 with a 3A flash light driver: https://www.fasttech.com/products/1...-xm-l2-u2-4c-1100lm-4300-4500k-led-emitter-on and https://www.fasttech.com/products/1...2mm-3000ma-1-mode-dimmable-led-driver-circuit
The Chinese donor case: 1156 High Power BA15S P21W 12V 5W CREE Q5 Car Bulb White Reverse LED Light New | eBay
I'll let you guys figure it out from the pictures--one tip, the case will need to be machined at the bottom to fit the driver. - Ok some of you may not have a mini lathe or access to one.
With the right relay you should not have hyperflash. I am 100% led for all exterior and most interior lights no issues at all.
All exterior LED lights need to be encased in plastic as the ones that show exposed board etc will depend on your housing being waterproof.
Got my relay from sbl like many others. Quieter too..
