Anyone have steps or pics of removing plastic driver side cover?
Phoenix, AZ
I'm trying to figure out how the lower plastic cover below the steering wheel removes (without breaking it). I removed the little screw on the bottom left, and found two pinch clips at the bottom, as well.
After that it still seems pretty tight onto the dash still.
Does anyone have pics, instructions or a link I couldn't find on how to remove this? I want to access the brake bolts thru the firewall easier.
Thanks!
just gently pry it away. The rubber ring around the key may hold it on too...I think I took that off first so I'm not sure.
Take the black piece under the gauge cluster off first...
You'll also need to disconnect the fuel inlet cover and hood cables from their levers. Total of 3 bolts and 5 clips, iirc.
Steve
Ok, I'll give it a shot later today.
Thanks!
