OK, so it looked like I might have a leak under a toilet, so I took the thing off. (Nice way to use up a vacation weekend...
) First time I took it off since I moved in. Fairly recent house (18 years old).
To my surprise, the flange that sits on top of the closet bend is not flush or above the floor as expected, it's lower by 1.2"... And whoever put that thing together stacked 2 (!) wax gaskets on top of each other to try and bridge the gap between the flange and the horn. Clearly it was not waterproof but I am amazed it didn't leak more than it did. Seems pretty screwed up to me. I tried gently to remove the flange to see underneath and maybe raise it but it isn't budging. I don't want to mess things up more by prying it off.
Questions:
- is this common or did they screw up the installation?
- from a visual inspection, it looks like the flange was fitted on the cast iron drain pipe by melting lead between the 2. Is that possible or even usual? If so, so much for removing it, I guess...
- what would be the best way to bridge that tall gap? Are there thicker wax gaskets with plastic lips than the usual 1"? Or rubber / metal rings I could use as inserts (something like a spring spacer
)? Or put a new flange on top of the other one with some sealant in between?
- the flange says 4x4 on it
D) does that mean it has a 4" long shoulder going down around the cast iron pipe? (Can't see it, there is mortar around it.)
other thoughts on how to fix this?
TIA
Questions:
TIA
