I had just bought my LC a couple months ago and noticed the other day my coolant was low. I read you aren't supposed to mix different kinds of coolant right?
So I went and bought 2 gallons of the toyota red concentrate to make 4 gallons of coolant (LC manual says it takes just under 4 gallons)
After reading a little more on draining and replacing the coolant I decided to let my mechanic do it. I had pre mixed one of the gallons of coolant with distilled water. So when I dropped my car off There was 1 unopened gallon of coolant, 2 gallons 50/50 coolant distilled water and 1 gallon of unopened distilled water (to mix with the unopened coolant)
Today I go to pick up my car and my mechanic says that it only took two gallons and that he put 1 gallon of the concentrate and 1 gallon of the 50/50 in making it 75/25 coolant to distilled water. Leaving me with a gallon of 50/50 mixed coolant and a gallon of distilled water.
Im worried about it only being two gallons and also the coolant to distilled water ratio.
I want to avoid spending anymore money so if it won't do any damage I'm fine with it. please help any advice would be appreciated.
-Matt
-Matt
