Another Waeco CF40 this time
Reno, NV
Another Waeco, CF40 this time
Here is another Waeco...
Coolmatic by Waeco CF 40 AC/DC Freezer - $350 (Sparks, Nevada)
Reply to: sale-6zs5b-1146373162@craigslist.org [Errors when replying to ads?]
Date: 2009-04-29, 1:18PM PDT
This is a rarely used Coolmatic cf 40 Portable Freezer/Refridgerator that operates on AC or DC power. Great for your RV or Boat! In Excellent working order! MSRP on this unit new is $750.00. First $350.00 picks it up! CALL 848-1892 Below are the specs:
Coolmatic CF-40 AC/DC. Capacity 39 Quarts (1.3 Cu/Ft)
Operates on 12 and 24 volts DC or 110 volts AC
High-tech unlimited
The COOLMATIC CF-40 AC/DC box can be operated on almost any mains network. Operates on 12 or 24 as well as on 110 AC. The CF-40 AC/DC is easy to transport and features optimised dimensions. In terms of capacity, too, it's ideal for use in motorhomes and trucks as well as on yachts or boats. It can be safely fastened in the vehicle by means of the fixing kit. The Danfoss BDF compressor ensures extraordinary performance for both normal refrigeration and deep freezing, minimal energy consumption, optional solar operation, and superbly silent running.
Convenience technology
The COOLMATIC CF-40 is equipped with a special electronic system that controls, besides the standard functions, a variety of valuable extra functions. The quick-chill function, for instance, makes the compressor run at maximum performance until the desired temperature has been reached. The temperature is variable in a range between +10° and -18°C. Thanks to the memory function, the carefully pre-set parameters won’t get lost in case of a system restart. The emergency switch ensures reliable cooling in all situations.
Key Words: Portable freezer/refer, AC/DC Freezer, RV, Boat, Home.
CALL 775-848-1892 Thanks
My friend Ray (Reignman from Mud) from Chicago is buying this fridge. Can someone check this thing out in person just to make sure everything is cool with it before Ray sends the check?
He doesn't visit this site much so pls send a PM to Reignman
thanks.
ali
I contacted the seller & just waiting on some pics of the unit and freight quote. Any onsite inspection is greatly appreciated since ;)
Thanks Ali & all
Ray
