Build Another Prado in Montana
I was reading your post and thinking, wow, it must be SO EASY to work on the TDI with it oriented lengthwise like that.... then you went and said how awful it is working on the exhaust manifold... lol.
I replaced my wife's exhaust manifold and turbo on her car. As you know, all that is behind the engine and against the firewall. What a pain that is.... just trying to put it into perspective for you!! Your setup is a dream to work on in comparison. I am impressed with how well the little 1.9 is moving about that 70 series metal box around for you as well as it is. They are indeed impressive motors for those who know how to look after them. :cheers:
Yeah, accessing the turbo in a stock application is miserable. The trouble with my setup is that while it looks all out in the open, everything is packaged in such a way that it renders several fasteners completely inaccessible to any tools that would be able to provide sufficient torque. Two exhaust manifold studs are buried between the turbo and the intake manifold, one has an EGR port stud in front of it, one of the downpipe bolts is only accessible using a stubby open end wrench, and several intake manifold bolts can only be reached with an Allen wrench doing 1/6 of a turn at a time. I'm working myself up to spending a lot of money to improve the situation.
There are a couple of exhaust manifold options. SPA Performance Fox/Dasher T3 manifold:
Vanagon 1.6TD "JX" engine code manifold:
And then of course the true party piece, a GTD1752vrk. Should be good for 30psi and pretty extreme EGT's, though hopefully it will help reduce them some instead. A forward facing compressor outlet and v-band exhaust outlet will really simplify the charge piping and exhaust, I have an inquiry out to a company that offers these set up for top mount, waiting to hear back if they would do one with a flange exhaust inlet rather than welded to a manifold.
No luck so far on finding an outfit that will build a top mount turbo for me. There are several on the market but they’re all welded to a manifold. I need one flange mounted, half tempted to find a used one and see about modifying it.
Well, after reaching out to several turbo builders I found an outfit in Poland that is happy to build a top mount, v-band vacuum converted turbo for me. Based on recommendations from my tuner and others I opted to go big on the turbo, got a GTD2060vz and a set of 0.260mm injectors on the way. I'll be using a Vanagon JX code manifold with an adapter for the v-band and stepping up the exhaust to 3" to let the turbo breathe.
On my ALH I had 520 race nozzles, which in the end, I think they were a little rich. So the .260 may be perfect. I ran the BV43 turbo for a while and then upgraded the center section from the UK(used unit) to a BV43a. All while running a Malone tune. Not gonna lie, it was an awesome setup. A stock USA Passat exhaust manifold that the bv turbo bolts up to. It had plenty of torque and what seemed like no top end, it would just keep going. May be a more simple option rather than custom made??
I did have to buy a heavier flywheel. It was too torquey with out the heavier flywheel!!
That was my original plan way back when I was first fitting a turbo, I had a complete BHW manifold and turbo but ended up running into lots of clearance issues with brake lines, steering shaft and starter. The turbo pretty much has to be top mount due to that, and to fit a turbo larger than stock I have to move it as far forward as possible to clear the brake and clutch master cylinders. Not much space on that side of the engine, unfortunately.
The first puzzle piece has arrived from Germany! Hoping to have all parts in hand by early September so I can start getting this thing put back together.
Somehow I didn't end up posting this. Found a weigh bridge this spring, had some tools and a few odds and ends in the back. 4740lbs, not bad for the little TDI to be pulling around.
After a long wait and a lot of added expense my new turbo finally arrived, and to my dismay it came welded to a manifold: exactly what I requested not to have done. Due to the current drawbacks of shipping things internationally it doesn't make sense to return or exchange it, so I think the best course of action will be to cut it off the manifold again and weld it to a flange.
That sucks.
Hopefully you'll get a solution worked out that is a better product in the end.
Yeah, what really stings is the $573 in tariffs on a $1050 part, which makes returning or exchanging a no-go. I've reached out to the turbo builder to see what can be done, ideally I would be able to get the correct exhaust housing sent and swap them over myself. Luckily on these 5th generation VNT turbos the VNT mechanism is entirely contained in the CHRA, meaning there is no adjustment required when swapping exhaust or compressor housings. Failing that I'll talk to some people more knowledgeable with welding than myself and see what it would take to cut the turbo off the manifold and weld on a flange to match my manifold.
The current turbo is a GT1749 from a BHW, injectors are 0.216mm and tune is a custom job from a guy on TDIClub. The new turbo is a GTD2060, new 0.260mm injectors on the way and will get a new tune for the upgraded hardware.
Who are you using on TDi club? My mk4 I believe is tuned, but I’m looking at pp764s or dlc1019s and will probably need another tune.
Everything seems good so far on mine, but always looking for a few more hp
His handle is burpod, he does an excellent job. My new tune is worlds better than the Malone stage 4 it replaced. You'll need VCDS and to get an MPPS dongle from him.
Alright I did see his name on there as a new guy. I’ll reach out. I do have VCDS/ross tech cable
Thanks! Sorry to hijack
Fired up the Prado for the first time in a month or so, it blew a massive cloud of white oil smoke. Oil was blown out of the failed downpipe gasket, and once I got the turbo off I found it had come from the #4 exhaust port.
I stuck a borescope up the exhaust runner, the inside of the exhaust port is fairly dry but the valve stem is practically dripping with oil. Looks like a failed valve seal, hopefully I can round up a rebuilt head to swap on.
Really poor photo of the borescope screen, but you can just make out the top of the valve stem where it goes into the valve seal/guide. The oil is definitely coming from there, it drains down the valve stem and pools on top of the valve. All four exhaust valves looked bad, but #4 was by far the worst.
Valve seals can be replaced with the head installed, but according to someone whose business is rebuilding TDI cylinder heads it is almost guaranteed that the guides are badly worn too.
Trying to decide between a new aftermarket head or getting this one rebuilt. I can get a complete, ready to install aftermarket head for around $1100 or get mine rebuilt. Not sure what a rebuild would cost but just the parts would be approaching $500 when figuring in a new cam, valves, lifters and gaskets. A new head would probably be much quicker too.
If you're in the market for 1019 injectors I'll have a set available in a month or two. Got them from Kerma a couple of years back, probably have ~20k miles on them. The hunt for more power never ends! I drove my brother's 400k mile Jetta again for a week and was again impressed by its power, especially at highway speeds. Going from 55 to 90 to pass a slow vehicle, without having to downshift, always brings a grin to my face! All it has are some no-name mild upgrade injectors, too.
