Hello, my 01 stranded me couple nights ago, had it towed to my place and have observed the following after reading many posts on here.
It has 140k now and the Timng belt was replaced at 100k
I have two keys, one that is new and has a metal tag with code attached, i tried this and my regular fob, the security flashes normal with key out, insert key and it stops asap.
Cranks over but it sounds weird , no metal sounds but like compression isnt quite right? But some times it does sound right, really ive not sat and listened to it crank as usually it starts right up. Ive heard it try to pop or fire only once.
I out in a new fuse in the efi 20amp underr hood, checked all others under hood and under drivers under dash, visual inspection ok.
I disconnected the fuel line on filter side that has the quick release and cranked it over and fuel filled a bottle i had with a couple cranks.
Pulled drivers front plug wire, not the plug and put in a plug i had and cranked it over and it sparked.
Odd thing i did see that was new as the engine has been super clean, i noticed oil had leaked down on the passenger side on the cv boot area, fresh oil i crawled under and it appears to dripping off the front exhaust bolt. Not a lot of oil , maybe valve gasket? Head gasket? Worse i was thinking head gasket but i think it would stilll run Or try to fire up..
I do not have a code reader, should i buy one to see if there are codes at this point?
I opened the oil filler and used a flash light and had someone turn it over and could see movement , so i believe the timing belt is still functioning.
I read on the maf, i know the fiilter was changed 3k ago and looks new, is the MAF right oast where the black intake connects with the riound clamp? Do i need to remove the whole air box etc to get in to inspect?
Thanks for any help.
