Been having a couple of recurrent "problems" with my electrical. Don't know if they are related or not. BJ70/71 24V
First, Every once in a while while driving, the usual lights that stay on until you rev the engine to about 1400rpm on start up start to flash for no aparant reason, usually in synce with the hazard, that is they flash at the same cycle that the hazard lights cylce. Like the Alt is turning itself off and on, like the reverse current relay is confused? When it has done this for a extended period of time, like more than one or two clicks, if I turn the head lights on, it usually quits doing this.
Second, the volt needle and the lights do the jig at all times. That is, the needle bounces from about 26v to 28v and the lights go from normal bright to dim back and forth at about the same rate that he voltage needle does it's thing.
Is the alternator on the 13B-T the same as on the 3B?
Thanks.
Thanks.
