[quote author=tclndcrz link=board=1;threadid=8209;start=msg70207#msg70207 date=1070394848]
i just checked and the bolt is fine.
Landpimp i like your setup. I hate wiring and dont know enough about it so where the hell is my wiring going from my alternator. Looks like it is going back into my truck. And you said you left the alternator wiring alone but ran the 1/0 wiring beside it? Im confused. Help! I want to be prepared before this thing dies on me.
[/quote]
For some reason I had a blast doing the wiring.....but I kinda like that kinda thing.
the stock alt wiring goes from the alt into 3 fusible links(on a fj60 at least, a 62 will be similar) I left all this in place as the 2 of the links must be left intact. So what I did was make up a 1/0 cable(2 guage would be OK) ran it from the alt(the screw post on the rear) to the Mega Fuse then to the battery, super simple. So now the stock wiring is still in place but if/when the MG puts out some major amps it will have 2 ways to go.....and it will take(hopefully) the path of least resistance(the 1/0 cable) I have been told my theory makes sense........so that makes me happy.
You don't need to mess with the wires in the plug on the rear of the alt, leave them as they are.
Your stock fusible links should be close to the battery, they look just like a wire(as they are a wire that is ment to burn out before the normal wire) there will be a conector of some type on the alt end, the other end might go right to the battery. But again.....you don't need to mess with this.
this pic might help(its a fj60, your alt is on the driver side under the air pump) but the alt should look similar.
see the 2 white wires? they are the stock wiring going to the battery(thru the stock fusible link). The large black wire w/red end is the new cable I ran to the battery(and thru a Mega fuse), they both hook up to the same post on the alt.
the green plug is the stock harness(for sensing voltage or something, I forget) on the MG it plugs into an adapter that goes to the alt........no need to mess with this, it's just a plug in deal
Short version, run a bigger cable/wire from the alt to the battery, leave the stock wiring just like it is.
Ask away if it doesn't make sense(or even if it does) I can look at our fj62s and see what if anything is different, but it should be very similar.
John H
