For Sale Alpine Flex MRP-406 Amplifier
Seattle, WA
I have a used alpine MRP-406 that I don't need anymore. It is a 2/1 channel amp with 60 watts rms x2 or 120 watts rms bridged. It packs a powerful punch for having the dimensions of about a medium sized book. I think it might have fit perfectly in the rear right quarter panel of my FZJ80 but decided to do an integrated removable box with a different amp instead.
Price is $45 plus shipping. Thanks!
Here are the specs:
[SIZE=+1]Features[/SIZE]
No Current Limiting
Continuously Adjustable Gain Control
Both sides Terminal Layout
Gold Plated RCA Input Connectors
Speaker Level Inputs
Gold Plated Power Screw Terminals
Gold Plated Speaker Screw Terminals
Noise Elimination Coil
Duo Feedback Circuit
Solid Copper Bus Bars
MultiMode
Top Mounted LED Power Indicator
Fixed Crossover (HP/LP)
2/1 Channel Operation
MOSFET Power Supply
DC-DC PWM Power Supply
Double Buffered Pre-Amp Input Circuitry
Discrete Pre-Amp Stage
Darlington Bi-Polar Outputs
STAR Circuitry
[SIZE=+1]Specifications[/SIZE]
RMS Power (at 14.4V,20Hz-20kHz)
Per channel into 4 ohms- 40W x 2 (0.08% THD)
Per channel into 2 ohms- 60W x 2 (0.3% THD)
Bridged 4 ohms- 120W x 1 (0.3% THD)
10% THD Power (at 14.4V)
Per channel into 4 ohms- 60W x 2 (1kHz)
MAX Power (at 14.4V,EIAJ)
Per channel into 4 ohms- 90W x 2
Bridged 4 ohms- 240W x 1
General-Amplifiers
Heat Sink (WxHxD)in- 5-1/2O x 9-7/16O x 1-3/4O
Foot Print (WxHxD)in- 5-1/2O x 10-1/4O x 1-3/4O
Slew Factor- greater than 5
Input Impedance- 10k ohm
Speaker Impedance- 4 or 2 ohms(stereo), 4 ohms(bridged)
Dividing Network- Fixed 80Hz HP/LP (18dB/oct)
Power Requirements- 14.4V DC (11V to 16V)
Heat Sink (WxHxD)mm- 140mm x 240mm x 45mm
Foot Print (WxHxD)mm- 140mm x 260mm x 45mm
Weight- 1.6kg(3lbs. 8oz.)
Frequency Reponse- 10Hz-50kHz (+0,-1dB)
Signal to Noise (S/N)- 100dBA (referenced to rated power)
Input Sensitivity (for rated power)- 200mV ~ 4.0V
