Wanted Al, Need Vacuum Advancer, 19220-60072
Andalusia Al
Toyota part # 19220-60072, 1977 2F Distributor, need vacuum advance only. Would like new but if not available, good used is ok, Thanks Paul
Toyota part # 19220-60072, 1977 2F Distributor, need vacuum advance only. Would like new but if not available, good used is ok, Thanks Paul View attachment 2019761
can you post the Nippondenso part #
if it matches this 6 Cylinder NOS TOYOTA bad boy then it does ............................ :grinpimp:
I have this if it’s whats you are looking for:
Guess I might have wrong part number. The part looks correct except mine does not have the white adjust piece. My distributor is
Nippon # 19100-61021 with no adjuster. I have not taken the advancer out and looked at it to see if this one will work. Does the white piece slide off the end shaft? Please look closely at my first picture and you will see the problem . It might work if that piece slides off, heck, I don’t know,
