I don't know of a front airbag. However, the torsion bars can increase their force by adjuating the preload bolts. Lota of threads about that around here.
Rear airbags are made for increasing load carrying capacity. You shouldn't need to adjust the height sensors for this. At 288k, I expect your tbars and coils are a bit tired. Again tightening the tbars is a cheap fix. OEM coils aren't super expensive. If you are always running heavy, used non-AHC or used 80 series springs are even cheaper. If you aren't running heavy all the time, a little lift by sensor adjustment may be required to get the Neutral pressure within spec.
If it is lift youre after, Ive read a few posts of folks successfully adding more spring (or spacers) and adjusting the height sensors to get a lift. (Note, if you go too much lift, you will run lut of room for High mode for the AHC, if that matters for you.) The rear airbag will lift the tail of a non-AHC cruiser, but this is usally done to compensate for overloading the springs and to get back to a normal stance. I don't know if airbags are made for continuous duty or if I'd want to rely on the airbags all the time.
