Air compressor QD fitting through ARB bumper
Chandler, AZ
Not sure who has it, but I'm interested in finding an quick detach air fitting that can mount through a drilled hole in my ARB bumper. I currently have a QD fitting on a 2ft extension that I pull through the front hi-lift mounting point to air up tires, however I'd like to permanently mount it. I believe whoever had one also had a black cap that covered the opening which had a 1-2" lanyard connected to the base of the QD (similar to a gas cap with attachment to the gas door).
Any ideas where I can get one of these parts?
Thank you! I looked quickly and did not find the cover, but I will check again...
Left side menu scroll down to the - click "Hose Fitting Products" then "Hose Fitting Dust Caps" then click on "Quick-Disconnect Hose Couplings" - there is the rubber covers
