Hi. I bought a 2000 LX470 in 2008. It has 80,000 miles and it's been a great car.
I am looking for some help troubleshooting an AHC problem.
Since I bought the LX it's has a very stiff ride. Not bouncy, but stiff -- almost as if there's no shock dampening.
The LX isn't used off road, doesn't tow anything and isn't used to carry unusually heavy loads.
I have installed new Michelin LTX tires and I keep an eye on tire pressures, but the rough ride hasn't improved. I think I can rule out a tire problem.
The AHC system goes from normal height to high and low without doing anything unusual. THe AHC fluid moves 9 notches on the AHC fluid reservoir from low to high height. I think I can rule out an AHC pump problem.
The LX sits normally, not low to the grounds as I've read can happen if the accumulators go. And when I press down on the corner of each bumper, the suspension moves and rebounds as you'd expect. I've read that if the accumulators are bad the suspension won't move much. Based on what I've read I think I can rule out an accumulator problem.
On to the AHC fluid: at the normal height setting, the fluid level in the reservoir is a couple of notches below the minimum level. I asked my dealer last year if the AHC fluid should be flushed. He said no, unless there's a problem. But I just noticed that the owner's manual recommends the AHC fluid should be changed at 60k miles. I have all of the service records for the car and and the AHC fluid has never been flushed. Is it possible that changing the AHC fluid or at least filling the reservoir to above the minimum level will help the ride quality?
I mostly understand how the accumulators work. Is it possible that the shocks on the LX are bad based on age and / or mileage? Do the shocks on an LX470 with AHC effect ride quality?
Finally, if the suspenion is out of spec could that be the problem? For example, could the neutral pressure be set incorrectly or the torsion bars not be tightened properly?
If I can get some troubleshooting advice from you all then I'll be able to steer my dealer in the right direction. I don;t want the dealer to randomly start changing (expensive) parts without. Thank you.
